Quickly setup your remote work environments with SOILVISION [video]
www.youtube.com/watch
Working Remotely is easy thanks to CONNECT Licensing
  1. Make sure to be a CONNECTED user
    1. Go to the CONNECT Center: https://connect.bentley.com to find your Company Site Administrator. See How are you connected link below your name.
  2. Download your SOILVISION software
  3. Install SOILVISION including CONNECTION Client
  4. Sign-in into the CONNECTION Client.
  5. Start SOILVISION and set entitlements
If it does not work out, reach out to:
