| Product(s): | Exor TMA | ||
| Version(s): | 4.5.0.0 | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
Selection Criteria lists are built up of available values
for each field and the list is headed by e.g. ::: All Contractors :::
If the first character of one of the values contains a character before ': ' in the ascii table e.g Space or - then the ::: All Contractors ::: is not displayed
but is available to be selected from the dropdown list.
Steps to Resolve
Option 1 Select ::: ALL Contractors ::: or appropriate value
1. Re-run Report selecting the ::: ALL Contractor ::: option
Option 2 Edit offending record
1.Locate the offending record. (you may need to send a Data Alteration Notice)
(If the '::: ALL Contractors :::' is preceded with a space character, this will help to stop this happening again)
2.Re-run Report
