Defect / Enhancement
Description | ||
1079182
Weight calculation tool was implemented in ProStructures CONNECT Edition | ||
1082120
.Net / VBA connections can now be deleted in one Go | ||
1092903
Better messaging for non-compatibility of DGN with former versions | ||
890951
View title can now be adjusted in the drawings in the Detail Center | ||
1076036
IFC Export: Groups are now correctly mapped with IFC Assembly | ||
1072271
IFC Export: Properties for StruMIS are being appropriately populated in the exported IFC file | ||
ISM Import: improved mapping of Weldshapes, Roof Wall Shapes, Combined shapes, Parametric sections, custom Sections and build up sections | ||
1078798,1078799.1078801, 1089440,1090127,1090190, 1086623,1086624 |
ISM Export: correct mapping as table sections, fixed properties and workflows | ||
1090081
NC: Part count correct on first choice with Option selected elements | ||
1076020
Positioning Start Number for Part Family - Validation for ranges is implemented | ||
1074916
Printing- ProStructures objects are now honoring pen table settings | ||
1070098
The external part list is now getting the drawing (revision) index number | ||
1070107
In drawing part list contains now also drawing number, index (revision) and name (file path) | ||
1074330 |
Real Section display for flange lines in 2D display improved | ||
1077617 |
Display of second washer enhanced | ||
1068334 |
Radius dimensions have been enhanced | ||
1074576, 1074578, 1074581, 1074582 |
Resizing in display and process dialogues enhanced | ||
1067421 |
Standard handrail can be placed on smart line now | ||
1064076 |
Stretching of arc shapes is now possible | ||
1052324 |
Item types can now use ProStructure properties with expressions | ||
1098461, 1098464, 1076930 |
ARMA Export with Bar Grade and Shape Name and other Improvements | ||
1036997 |
Undo does not duplicate Rebar Labels undercertain circumstances | ||
860755 |
Bar Grades appear now always on first time label insertion | ||
1105684 |
Move labels is now always working | ||
| 927345 | 2D Bars are created with multi reference files | ||
| 927345 | 2D Bars are improved for curved Bars | ||
| 1061262 | Size of Bar end is now controlled by HDIA variable | ||
| 1090262 | Long bars are updated under all conditions now | ||
| 1104289 | Rebar Color is correct after applying modifications | ||
| 1103534 | Rebars are selected as whole in all cases for positioning and part list | ||
| 1083361 | Crash after 2 time undo of certain Rebar sets | ||
| 1085309 | PC Toggle tools: Selection is reflected in the PS_Properties | ||
| 1036725 | All Rebars are displayed when using circular opening | ||
| 1020646 | Irregular dispatch: "Make Arc intermediate Point" gives always exact results | ||
| 1058400 | Rebar couplers are displayed for copied Rebar sets | ||
| 863081 | Bar marks are retained after stretching | ||
| 933428 | Rebar Selection can be controlled better | ||
| 934534 | PC DWG Export for 2D bars improved | ||
| 1086956 | Bar mark assignment for single bars improved | ||
| 1103885 | Bar marks appearing now in tooltips and Properties after positioning | ||
| 1065838 | Printing of Rebar elements improved for 3D Pdf | ||
| 1103110 | Select all performance with open element information pane enhanced | ||
| 1103226 | Concrete and rebar positioning is speeded up in execution | ||
| 1079685 | Clash detection (Power Platform) is now available without beeing licensed |
