MicroStation Connect crashes when started (Trend Micro)
 Product(s):MicroStation
 Version(s):10.07.00.41
 Environment:N\A
 Area:Other
 Subarea:N\A
MicroStation Connect crashes immediately when started. No exception logs created.
Note: Kindly contact your Antivirus vendor and request for details on threats, security issues reported on Bentley Products.
          Share the data by logging a Service Request so our Support team can review them.
          Do also share the Event logs - check video.
Event logs shows tmmon64.dll "Trend Micro UMH Monitor Engine" is the faulting DLL.
Add the following files/folders to the antivirus exclusions
C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\MicroStation.exe
C:\Program Files\Common Files\Bentley Shared\CONNECTION Client\LicService\Bentley.Licensing.LicenseTool.exe
C:\Program Files\Common Files\Bentley Shared\CONNECTION Client\Bentley.Connect.Client.exe
C:\Program Files\Common Files\Bentley Shared\CONNECT Advisor\Bentley.Connect.Advisor.Service.exe
C:\Program Files\Common Files\Bentley Shared\CONNECT Advisor\Bentley.Connect.Advisor.Api.dll
For MicroStation 2023 use the following path
C:\Program Files\Bentley\MicroStation 2023\MicroStation\microstation.exe
Excluding a file or application
Recommended scan exclusion list for Trend Micro Endpoint products
Other language sources
Deutsch
