| Version(s): | through 08.11.13.140 | ||
| Area: | Installation_Configuration | ||
| Subarea: | N\A |
At startup, the following or similar error message is displayed and catalog items such as symbols cannot be inserted.
Internal Error
UI Error Message: ExecuteSQL error. create PROCEDURE BlkInfo AS select
blkName,anum,blkDesc,desc_id,type,date_modify,category,0 AS FileInfo_id,blkSymXML from sym0
The Microsoft Jet database engine cannot find the input table or query 'sym0'. Make sure it exists and that its name is spelled correctly.
TargetSite: Void ExecuteSQL(Int32, System.String)
DeclaringType: MDBProxy.LocalTools
Attributes: public
MemberType: Method...
This message can indicate a problem with the Device.mdb file. In one case it occurred after incorrectly trying to [[Rename a catalog|rename a catalog]].
Refer to the following articles for the path to Device.mdb and a link to a fresh copy of this file.
[[Device.mdb - Promis.e]]
[[Device.mdb - Substation]]
Rename or delete the suspect Device.mdb.
Replace the Device.mdb with the known good copy of Device.mdb.
| Original Author: | Matt_P |
Keywords: sym1, sym2, dev0, dev1, dev2, mac0, mac1, mac2, tit0, tit1, tit2
