| Version(s): | V8i, CONNECT, 2023 | ||
| Area: | Cells | ||
| Subarea: | General |
The following Wiki shows you how to create new cells using MicroStation V8i, MicroStation CONNECT Edition, & MicroStation 2023:
There is a small difference between the two versions of the software.
In MicroStation V8i, the create button is on the bottom right:
In MicroStation CONNECT Edition & MicroStation 2023, the Create icon is on the top left:
Video - MicroStation V8i
Video - MicroStation CONNECT Edition & MicroStation 2023
How to place cells in a *.dgn file
| Original Author: | Mara Manconi |
