ISSUE: Getting a message "No elements found. Do you want to discard changes?" when trying to create a new deck template:
RESOLUTION:
- Change the Workflow to "Drawing"
- Right click in the Attributes area and activate "Element Class"
- Change the Element Class from "Construction" to "Primary"
- Save Settings for the file
- Create or edit the deck template in the OpenBridge Modeler > Utilities > Decks workflow
