Components By Type
Click on the links in the left column below to see a full list of components available for each component type. You can then click on the additional tags to filter components for your specific region/configuration pack.
Component Type | Description |
Borehole Log Templates | Borehole Log templates. Available as .hbt files that can be loaded into Template Studio. |
Borehole Strip Templates | Borehole Strips for use with Master Templates. Available as .hbt files that can be loaded into Template Studio. |
Charts | Charts contain a zip file that contains a chart object, and any corresponding templates that can be used with that chart. Import as a component in Professional. |
Civil Templates | Civil Templates that can be used in conjunction with Civil Strip Templates. Available as .hbt files that can be loaded into Template Studio. |
Civil Strip Templates | Civil Strip Templates that can be used in conjunction with Civil Templates. Available as .hbt files that can be loaded into Template Studio. |
Civil Symbols | Civil Symbols that can be used in the AutoCAD Civils Extension. |
Data Collector Profiles | Data Entry Profiles for use with the Data Collector Mobile Application. Available as .hbc files that can be imported as components. |
Data Entry Profiles | Data Entry Profiles for use with the Data Entry Application. Available as .hbc files that can be imported as components. |
Excel Templates | For use with the Excel Extension. Available as .hbc files that can be imported as components. |
Hatch Symbols | Hatches used within Picklists. Available as a collection of images that can be setup and imported into Professional. |
Paper Sizes | Paper Sizes to be used with all template types in Professional and Template Studio. Available as .hbc files that can be imported as components. |
Picklist Images | Images used within Picklists. Available as a collection of images that can be setup and imported into Professional. |
Picklist Symbols | For use with plotting symbols down a borehole log. Available as .hbc files that can be imported as components. |
Quick Section Templates | For use with Quick Section Strips. Available as .hbt files that can be loaded into Template Studio. |
Quick Section Strips | For use with Quick Section Templates. Available as .hbt files that can be loaded into Template Studio. |
Read Only Templates | Borehole Log and Other templates. Available as .hbc files that can be imported as components. |
Report Views | Report Views that can be imported as components. |
Site Plans | Site Plan Templates. Available as .hbt files that can be loaded into Template Studio. |
Components By Region / Configuration Pack
Click on the links in the left column below to see a full list of all components available for each region/configuration pack. You can then click on the additional tags to filter to specific component types.
Region / Configuration Pack | Description |
Australia (Aus) | Components designed to work with the Australia configuration pack. |
North America Metric (NAM) | Components designed to work with the North America Metric configuration pack. |
UK | Components designed to work with the UK configuration pack. |
US | Components designed to work with the US configuration pack. |
Legacy - British Standard (BS) | Components designed to work with the legacy British Standard configuration pack. |
Legacy - ASTM Imperial (ASTM-I) | Components designed to work with the legacy ASTM Imperial configuration pack. |
Legacy - ASTM Metric (ASTM-M) | Components designed to work with the legacy ASTM Metric configuration pack. |
