iTwin Services for Engineering Analysis Early Access Program (EAP)
Do you use STAAD, RAM Structural System, RAM Concept, or SACS?
Would you like to leverage cloud collaboration to optimize your design review workflows and resolve issues more quickly?
Join Bentley’s Engineering Analysis Early Access Program (EAP) for a truly customized experience. You can use your own structural models to test drive new and emerging technologies.  This solution leverages ProjectWise 365 to provide a suite of tools and features for the practicing structural engineer. You can:
The EAP is a time-limited, collaborative program between Bentley and approved companies. You can explore, learn, access, and provide feedback on the latest cloud collaboration technologies while working directly with Bentley’s Engineering Simulation product team.
Interested?
Spaces are limited for this special opportunity. Complete the form, and a product expert will get back to you shortly.
Select your software:
Learn more about iTwin Services for Engineering Analysis.
