| Version(s): | ALL |
| Area: | Material Update |
| Date Logged & Current Version  | March 2020  41.04.00.013  |
How to make modification to existing standard flange material ?
Right click on a component and select “Change Material”:
Select nozzles which need to be modified:
Change the "Symbolic Name" material setting as needed (ex. SA 105):
Change "Apply Change" setting from "Main Component" to "Nozzle Flange Material” to apply selected material on nozzle flange material:
Enable “Change Material” checkbox to apply selected material on selected components:
Click “Apply” to apply modification.
For body flange as standard flange, select “Main Component” instead of “Nozzle Flange Material”
