| Version(s): | N\A | ||
| Area: | Print/Plot | ||
| Subarea: | N\A | ||
| Original Author: | Beverly Dawn Gentry, Bentley Technical Support Group | ||
How do you convert saved views in a DGN file to bookmarks in a PDF file using MicroStation printing?
MicroStation Print does not have this functionality like InterPlot/IPLOT does. A workaround would be to add the design file multiple times, for each plot in the pset, set a different Saved View as the plot area, then create one PDF from all the files.
