Improve plant design and operations with a collaborative, intelligent, 2D, and 3D plant design solution within a digital twin environment. Accelerate the next project with a multi-discipline 3D plant design environment to model piping, HVAC, and electrical components with the ability to leverage Bentley’s iTwin framework.
Open plant modeling for better designs
Learn how to perform 3D design of plant piping, HVAC, and mechanical and electrical equipment quickly and easily in an open and collaborative digital twin environment by leveraging Bentley’s iTwin framework.
Training Course (LEARNserver)
Training Course (YouTube Video)
Efficient piping diagrams
Learn about improving plant design and operations with fast, intelligent, and accurate P&IDs you can share across your project using the ISO 15926 open data schema.
Training Courses (LEARNserver)
Intelligent and automated isometric drawings
Learn to quickly create intelligent isometrics from multiple 3D model sources in a collaborative, interoperable, and stand-alone application.
Training Courses (YouTube Videos)
Engineer supports from a catalog of pre-built supports
Learn about fast and accurate design, modeling, and detailing of support for piping, electrical, and HVAC components.
Conquer complexity with unified design
Learn how to save time and reduce costs with the first and only integrated application for cable system layout, routing, and material estimating.
Provides full step-by-step training through an established learning path. This learning path provides videos from recent Plant Design Special Interest Group virtual workshops.
Plant Design Special Interest Group Learning Path
Provides various short overview videos on program features and capabilities.
OpenPlant Modeler is the accurate, rapid, design engineering solution for 3D plant design.
OpenPlant PID is an easy-to-use, data-driven application for the rapid production of P&IDs, allowing users to cap.
OpenPlant Isometrics Manager is a flexible, powerful application that runs independently from expensive plant design systems, allowing non-engineers to quickly create and manage isometrics.
OpenPlant Support Engineering enables EPCs and plant owner-operators to accelerate the design, modeling, and placement of supports and support assemblies, reducing overall project design time.
Designing complex raceway and cable systems used to require multiple software applications to handle the wide range of design and documentation tasks typically involved.
OpenPlant Raceway and Cable Management
OpenPlant ModelServer V8i (SELECTseries 5) is the most flexible plant design software on the market today supporting distributed project team members with robust access control and management, highly visible status tracking, and efficient data exchange.
HEEC Implements BIM Process to Deliver 220kV Indoor Substation in Congested Wuhan City
Provides Wiki articles, forum information, blog posts, files, and ideas.
