| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | |
| Date Logged & Current Version | Sept. 2017 11.01.00.17 |
Design factors according to the code are:
AutoPIPE help has the design factors set to:
Why are they different?
The user is able to select 2 different codes from the General model options dialog: ASME B31.4 Liq. Trans or ASME B31.4 OFFshore.
Table 403.3.1-1 shown above is for ASME B31.4 Liq. Trans piping, while AutoPIPE's help table shown above is for chapter IX (offshore piping) referenced by table A402.3.5-1
These are the exact values as referenced in AutoPIPE's help. AutoPIPE will use the correct allowable values for the selected piping code.
ASME B31.4 Chapter IX (Offshore) Piping Code Calculation
