| Version(s): | 10.10+ |
| Area: | Drainage and Utilities |
Question:
How can I change the Node Draw Type of my Profile Run?
Answer:
Before creating your Profile Run, you can set a preferred Node Draw Type in the file settings.
After creating your Profile Run, you can change your Node Draw Type using the Properties dialog.
