Resolved issues
Bentley OpenUtilities V8i (SELECTseries 4) 08.11.09.802 - Update 3 Resolved Issues List
ID
Title
683882
Linked attribute updates with multiple feature instances at one work location
679460
Localized OpenUtilities PowerView Help menu does not work
679456
Localized OpenUtilities PowerView does not include print prep
679047
Performance issues streaming spatial data with relationships
678470
Moved the Database folder from Installset to deployment
669033
OpenUtilities Workflow Manager Splash screen obscures the latest CONNECT Center Login
664650
Unable to edit the value of an Integer type Global Attribute in Job Default Assistant
658720
Text global defaults show incorrectly in Design Assistant
654180
Design validation status is not reset by changes to the design
653645
Display Connection setting does not work on SQL Server
653644
Performance impact of large landbase features in Design Assistant
652055
Undo & Redo of Pole deletion in Design Assistant causes crash
651518
Disassociate not available in Work Request view
651514
Error when submitting multiple copies of a CU Assignment at a Work Location
644898
Job Scheduler has an Unhandled exception and crash on selection of Help About
639165
Inconsistent error on expand path in Design Assistant
639149
System error "DELETE statement conflicted" occurs when deleting a span with an existing Points-Only Non-Split work location
637294
Folder Custom Queries are limited to 1200 chars
631486
Sporadic crash on Get Selection of Underground Secondary
631483
Gas Casing not attaching to gas main
624503
OpenUtilities Power View - Print Prep is not on the Utilities toolbar
623737
OpenUtilities Powerview - two “Print” options under the “File” pull down menu
619961
ctrl keys do not work in comments dialog
615729
Design Assistant find in unit catalog highlights but does not select result
615727
Design Assistant Find button is not the default button
613617
Model Administrator macro is causing virus scan to report false positive
591896
Renumber of Work Location with no annotation in the Bentley desktop GIS causes a crash
591894
Job Scheduler service fails with max size password
591891
Job Scheduler UI is not showing status correctly when it’s not running as a service
567874
PrintPreparation is not working in OpenUtilities PowerView
539831
Outage Planner tool can crash with small networks
538454
Edit Feature and use of MS_GEOXFM_NO_DYNAMICSCOREDFEATURES=1 raises GetConnections failed error message
538390
Model Administrator - AddSymbologyAdditions is not getting processed
527294
Drag and drop of non-Proposed Install features causes an error
527292
Copy paste of features between Work Locations is inconsistent
495432
Ungraceful exit when trial license has expired
444693
Leak analysis cross tab report has 'mile' in the label
439919
Breaks per year per length calculation is wrong
434860
Unable to access XfmStdUtilPlacement.XFMStdPlacementEventHandler in mvba
434591
Plan Outage action (Create OutagePlan design fails) when only the Water Configuration is loaded
434589
Corrected Water>Outage Plan Workflow
433988
Exception can occur when editing referenced features outside the OpenUtilities data models
388449
Smart Move and Smart Modify are not handling design comments
365899
[Smart Move and Smart Modify are not handling multi-line text
