Applies To | |||
Product(s): | InRoads | ||
Version(s): | 08.11.07.615 | ||
Environment: | N/A | ||
Area: | Reports | ||
Subarea: | |||
Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
What is the suggested method to get the distances between two different alignments?
The suggested method to get the distances between two different alignments is the Station Offset Report (Tools>XML Report>Station Offset). This report will allow you to select your baseline alignment and your offset alignment and report on the offset (distance) between the two. This command will also allow to you to select your desired for which this data is reported.
