| | Product: | MicroStation | |
| | Version: | V8i, CONNECT | |
| | Environment: | N\A | |
| | Area: | Configuration | |
| | Subarea: | General | |
Problem Description
Generally the color table used on a design file is the default selected in the current workspace. In some circumstances a specific color table can be attached to the design file that overrides this default color table. The following shows a workflow that can be used to remove this attachment.
- Open MicroStation
- Enter the key in: CT=<spacebar> (press the spacebar and press enter)
This will detach the attached color table. - To attach the new (default) color table, open the Configuration Variables dialog box
- Select Colors-> Highlight MS_DEFCTBL Default Color Table from the upper right window on the palette.
- Click on the select button and select the correct color table (example color1.tbl) ->ok
- This will prompt an alert from MicroStation, asking if you really want to save changes to your .UCF file (user configuration file).
- Choose Yes and the color table will be attached each time MicroStation is launched.
- Exit MicroStation and re-enter for the changes to take effect.
Other language sources
Français
| | Original Author: | Maria Munoz | |
