Error - OraOLEDB.Oracle provider is not registered
 Product(s):Promis.e, Bentley Substation
 Version(s):through 08.11.12.73
 Environment:Oracle
 Area:Database Platform Support
 Subarea:N/A
Error or Warning Message
Unhandled exception has occurred in a component in your application.  If you click Continue, the application will ignore this error and attempt to continue.
The 'OraOLEDB.Oracle' provider is not registered on the local machine.
How to Avoid
  1. Start a command prompt as an Administrator.
  2. Change directory to the Oracle Home > \BIN directory.  For example:
    cd \oracle\product\11.2.0\client_64\BIN
  3. Register the .DLL.  For example:
    regsvr32.exe OraOLEDB11.dll
External Links
Start a Command Prompt as an Administrator
 Original Author:Matt_P
Keywords: parts database
