| Product: | MicroStation | |
| Version: | V8i, CONNECT | |
| Environment: | N\A | |
| Area: | Coordinate Systems | |
| Subarea: | General | |
How to export coordinates for the center point of circles in the design file?
I would like to export coordinates for the center point of circles only (not any other element) to the text file, how can I do that?
You can do that by Export Coordinates tool by following these steps:
The tool can be found through XYZ Text-tool which you can enable from Tools > Tool Boxes… In the opening Tool Boxes dialog scroll down, tick XYZ Text and click OK.
![](913c03f81bfd4a90f3fc5287624bcb72.iix)
Open Element Selection tool and expand it from the small arrow.
- Open tab Element Type and from the Element Type list select Ellipse > all the circles in the design file gets highlighted, but not any other elements.
![](423c0f3047fd82909091861f536d437b.iix)
In the XYZ Text toolbox click Export Coordinates tool:
![](1a3c0f3047fd82909091861f536d4388.iix)
Export Coordinates tool opens. Click Browse and select the folder for the export-file. Tick also the checkbox next to Point#, to get the order of the exported coordinates visible in the screen.
![](663c0f3047fd82909091861f536d4382.iix)
Click Single and confirm with OK the selection set. The text file with center point coordinates is created and the numbers in the circles displays the order.
![](c73c43f81bfd4a90f3fc5287624bcb16.iix)
The Power Of CSV
How to place a line using XYZ Coordinates using a Key-In Script
Other Languages Sources
Español
Italiano
![](633c43f81bfd4a90f3fc5287624bcbc4.iix)
| Original Author: | Anu Kuusiaho | |
