| Berechtigungskategorie | Kategorie-Beschreibung | Service/AppliKation | Berechtigung | Berechtigung-Beschreibung |
| Project Activities | Manage Project Settings for created projects | Project/iTwin | Provision Project from a Template | Provision a project from a template |
| Administration | Manage Administrative Setting / Access Control | Project/iTwin | Edit Project Properties from Portal | Edit Project Properties from Portal |
| Invite & Configure Team Participants | Invite & Configure Team Participants | |||
| Create / Modify Team Roles & Permissions | Create / Modify Team Roles & Permissions | |||
Remove Team Participants | Remove Team Participants | |||
| Access Team Member and Role Management | Access Team Member and Role Management | |||
| Manage Project Access and Billing Settings | Manage Project Access and Billing Settings | |||
| Manage External Organizations | Manage External Organizations | |||
| Create New iTwin | Create New iTwin | |||
| Share | Manage Access to Cloud Document Storage | ProjectWise Share | Read | Share Read Permission |
| Read / Write | Share Read & Write Permission | |||
| Read / Write / Delete | Share Read, Write, and Delete Permission | |||
| Configure Folder Access | Configure Folder Access | |||
| iModelHub | Manage Access to iModels | iModels | View | View and iModel in a web browser |
| View / Read | Read an iModel (download) | |||
| View / Read / Write | Modify and iModel | |||
| View / Read / Write / Manage | Create an iModel & Configure | |||
| View / Read / Write / Manage / Delete | Delete an iModel | |||
| ProjectWise ContextShare | Manage Access to Reality Data | Context Capture | Assign | Assign/Unassign Reality Data from a Project |
| Create | Create Reality Data and assign them to a Project | |||
| Manage | Manage Reality Data | |||
| Use | Use Reality Data | |||
| PS Federated Connection | Manage Access to PS Federated Connections | ProjectWise | Modify PS Federated Connections | Modify PS Federated Connections (Create, Update, Delete) |
| Scenario Services | STAAD | Create Solution | Create Solution | |
| Solution Create & Archive | Solution Create & Archive | |||
| Scenario Create/Update/Delete | Scenario Create/Update/Delete | |||
| Scenario Run | Scenario Run | |||
| View Result | View Result | |||
| Project Insights Service | Manage Access to View and/or Configure Insights | ProjectWise | View Project Insights Dashboard | View Project Insights Dashboard |
| Configure Project Insights Dashboard | Configure Project Insights Dashboard | |||
| ProjectWise Forms | Manage Access within Issue Resolution and Forms Services | ProjectWise | View | Gives user access to view forms |
| Comment | Gives user access to comment on forms | |||
| Create | Gives user access to create forms | |||
| Modify | Gives user access to modify forms | |||
| Assign | Gives user access to assign forms | |||
| Approve | Gives user access to approve forms | |||
| Delete Forms | Gives user access to delete forms | |||
| Manage Forms | Gives user access to manage forms in Issue Resolution and Forms landing pages | |||
| Create Dashboards | Create and edit dashboards for Issue Resolution and Forms landing page | |||
| Component Center | Manage access to components within Component Center | Component Center | Read | Component Center permission to read components |
| Product Settings Service | Manage access to settings for Bentley iTwin-powered applications | iTwin | Manage Settings | Allows users to create, update, or delete context settings |
| iModelDataManager | Manage Access to Tag Management Applications | PlantSight | Read SharedQuery | Read SharedQuery Description |
| Update SharedQuery | Update SharedQuery Description | |||
| Delete SharedQuery | Delete SharedQuery Description | |||
| Manage Briefcase | Manage Briefcase Management Administrators Page | |||
| Edit Data | Edite iModel Data in Queries | |||
| Set ReadOnly/Editable Column | Edit columns as readonly/editable using column option in Queries | |||
| Export Queries/Folder | Export Queries/folder from current project to selected projects | |||
| Set Advance Mode | Set Advance Mode on in Queries | |||
| Create New Query | Create New Query in Queries | |||
| Validation Service | Manage Access to Clash Detection | Design Validation | Create Library | Create Library |
| Delete Library | Delete Library | |||
| ResultSet/ValidationSet Create/Update/Delete | ResultSet/ValidationSet Create/Update/Delete | |||
| Model Run | Model Run | |||
| Quantity Take-Off Configuration Service | Manage Read and Write Access Controls for Quantity Rules | SYNCHRO Pro / 4D | Read/Write Configurations | Allow users to upload and update QTO configuration |
| Read Configurations | Configuration and apply it to models | |||
| iModel Schema Management Service | Manage Access to iTwin Design Insights Schema Management | iTwin | Query | Query Contexts |
| Upload | Upload Contexts | |||
| Delete | Delete Contexts | |||
| PdfGeoIndexingService | Manage Access to PDF Documents | SYNCHRO | PDF Read | Read PDF documents |
| PDF Modify Modify PDF documents | ||||
| SYNCHRO | Manage Control to Synchro Modules | SYNCHRO | SYNCHRO 4d | Access to SYNCHRO Modeler, SYNCHRO Open Viewer |
| SYNCHRO Control | Access to SYNCHRO Control | |||
| SYNCHRO Field | Access to SYNCHRO Field | |||
| SYNCHRO 4D Review | Access to SYNCHRO 4D Review | |||
| Guest User | Guest Permission for SYNCHRO | |||
| SYNCHRO Bid | Access to SYNCHRO Bid | |||
| SYNCHRO Cost | Access to SYNCHRO Cost | |||
| 4D Scheduling Permissions | Managing construction projects with 4D scheduling & simulation, model-based QTO, and construction modeling | SYNCHRO | Read Schedule | Read SYNCHRO 4D Schedule |
| Read Schedule Actuals | Read SYNCHRO 4D Schedule Actuals | |||
| Read Schedule Assignments | Read SYNCHRO 4D Schedule Assignments | |||
| Read Schedule Costs | Read SYNCHRO 4D Schedule Costs | |||
| Read Schdedule Resource Status | Read SYNCHRO 4D Schedule Resource Status | |||
| Read Presentation | Read SYNCHRO 4D Presentation | |||
| Read Documents | Read SYNCHRO 4D Documents | |||
| Read Issues | Read SYNCHRO 4D Issues | |||
| Read User Defined Data | Read SYNCHRO 4D User Defined Data | |||
| Write Schedule | Write SYNCHRO 4D Schedule | |||
| Write Schedule Actuals | Write SYNCHRO 4D Schedule Actuals | |||
| Write Schedule Assignments | Write SYNCHRO 4D Schedule Assignments | |||
| Write Schedule Costs | Write SYNCHRO 4D Schedule Costs | |||
| Write Schedule Resource Status | Write SYNCHRO 4D Schedule Resource Status | |||
| Write Presentation | Write SYNCHRO 4D Presentation | |||
| Write Documents | Write SYNCHRO 4D Documents | |||
| Write Issues | Write SYNCHRO 4D Issues | |||
| Write User Defined Data | Write SYNCHRO 4D User Defined Data | |||
| Write 4D Project Setup | Write SYNCHRO 4D Project Setup | |||
| ProjectWise Deliverables Management | Manage Permissions for Sending Transmittals | ProjectWise | Read & Create Draft Packages | View and create packages, view settings |
| Receive External Packages | Receive packages from external organization | |||
| Issue Packages | Issue draft packages, review & issue packages | |||
| Approve RFI Response | Review and approve RFI response | |||
| Manage Settings | Modify PWDM project settings | |||
| Document Registry Service | Manage Control of Documents | SYNCHRO | Create/Modify/Delete Documents | Create, modify, and delete documents |
| View All Revisions | Access to all document revisions | |||
| SYNCHRO Bid | Manage Access to Bid Management | SYNCHRO | Administer Procurement System | Administer Procurement System |
| Read Project Bids | Read Project Bids | |||
| Write Project Bids | Write Project Bids | |||
| Read Project Procurement Contracts | Read Project Procurement Contracts | |||
| Write Project Procurement Contracts | Write Project Procurement Contracts | |||
| Design Insights | Manage access to Design Insights, which provides project teams with analytics to understand the implications of design decisions | iTwin | ||
| Manage User Settings | Users can configure the following settings: Ancillary Data User Settings | |||
| Create Custom Dashboard | Users can create custom dashboards | |||
| Edit Custom Dashboard | Users can edit custom dashboards | |||
| Create Concept Comparison | Users can create concept comparisons | |||
| View Template | Users can view Templates | |||
| Edit Template | Users can edit Templates | |||
| Design Validation | Manage access to ProjectWise Design Validation for checking the completeness and quality of BIM data which is critical for reducing risk and generating actionable insights | ProjectWise | Approve Validation Script | Approve Validation Script |
| Engineering Data Manager | Manage access to tag management | OpenPlant | Create Tags | Create Tags |
| Delete Tags | Delete Tags | |||
| Edit Tags | Edit Tags | |||
| Edit Properties | Edit Properties | |||
| Manage Column Options | Manage column options - apply at iModel | |||
| PlantSight Portal | Manage access to functionality in PlantSight Portal | PlantSight | Dashboard Administration | Dashboard Administration |
| Show Acquisition | Show Acquisition | |||
| Show Aggregation | Show Aggregation | |||
| Show Data Manager | Show Data Manager | |||
| Show Documents | Show Documents | |||
| Show Insights | Show Insights | |||
| Show Issue Resolution | Show Issue Resolution | |||
| Show Validation | Show Validation | |||
| Show Visualizer | Show Visualizer | |||
| Show Forms | Show Forms | |||
| Machine Learning API | Manage access to Machine Learning | iTwin Design Insights | Run Inference Permission | Grants access to run ML inference jobs, default read-only |
| Labeling data in ML service | Labeling data in ML service | |||
| Insights and Reporting | Manage access to reports, which aggregate digital twin data from multiple sources into one unified format and place | iTwin | View | Access reports in Insights and Reporting for a context |
| View/Configure | Configure reports in Insights and Reporting for a context | |||
| SYNCHRO Cost | Manage access to construction contracts, budgets, and change orders | SYNCHRO | Cost system administrator | Cost system administrator |
| Setup cost contracts | Setup cost contracts | |||
| Manage cost configurations and workflows | Manage cost configurations and workflows | |||
| Data Manager | Manage access to data | OpenPlant | Create Tags | Create Tags |
| Manage Column Options | Manage Column Options | |||
| Release Tags | Release Tags | |||
| Create New Query | Create New Query | |||
| Read Shared Query | Read Shared Query | |||
| Delete Shared Query | Delete Shared Query | |||
| Renamed Shared Query | Renamed Shared Query | |||
| Export Queries/Folder | Export Queries/Folder | |||
| Promote to Shared Query | Promote to Shared Query | |||
| Set Advanced Mode | Set Advanced Mode | |||
| Extension Service | Manage iTwin.js Extensions | iTwin | Manage Extensions | Allows user to create and update an iTwin.js extension, as well as create different versions of the extension. |
Anderssprachige Quellen
TBD
