| Product(s): | Exor Network Manager | ||
| Version(s): | 04.07.00.01 | ||
| Environment: | Windows XP 64 bit | ||
| Area: | Install/Upgrade | ||
| Subarea: | N\A |
We currently have Network Manager 4700 fix 29 installed and your DTF8.1 notes state that Exor Core (Network Manager) update 32 needs applying. I have been able to download update 30 & update 32 but cannot locate update 31 - do I need to apply 30 & 31 before 32, if so where can I download update 31 from ?
If you have applied patch 29 then looking at the patches you have referenced, you can apply patches 30 and 32. Patch 31 is not available for release, so explains why you cannot see to download. Each fix release note has a section entitled prerequisites
Given you have fix 29 installed Prerequisites is Network Manager 4.7.0.x Fix 25 (Fix Number - exnm04070002en_updt25 which I assume sometime in the past has been applied ?
patch 30 has no prerequisites
Patch 31 - not released so unavailable
Patch 32 - Prerequisites exnm04070007en_updt13
So suggest apply in the order above, post doing you should be able to check within the application that the version number of the packages from file fastpath choose module about_server and then select run ( to check the version numbers reported match List of Amended Files version in each document). Form number versions are checked by going to the form and selecting help about and seeing the number in the 5th line from the bottom.
| Original Author: | Clive T |
