One can change station for a support line the following different ways:
- You can select the SupportLine and open the Properties dialog and change the station value from SupportLine Rule section:
- One could also select the SupportLine in view and open the properties dialog and change the station value:
- One could click on the station value in the View and change the station value:
- You can also open the Modify tool and change the station value:
