| Product(s): | InRoads | ||
| Area: | General | ||
| Subarea: | |||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
When trying to define cells in Point Symbology, the chosen cell is not held. For example, if you select a cell, close the Point Symbology dialog, and the reopen it, the cell field is blank.
Ensure that the correct cell library is attached in MicroStation.
