How to do a Complete Export from KeyLAB?
How do I export a Test from KeyLAB?
Explanation
If you need to obtain the test definition from KeyLAB there is a function available that will export the test definition, the sheets (input and output) and the AGS mapping files. Please follow the below process.
Process
To do this go to the sheets button on the KeyLAB Ribbon. Select the test which you would like to export. Right click and go to Transfer and then Complete Export
When selected you will be prompted to pick a file location. The file produced is a .zip file.
https://vimeo.com/703233600
Further Information
