Applies To | |||
Product: | RAM Connection | ||
First Affected Version: | 13.02.00.14 | ||
Found in Version: | 13.02.00.14 | ||
Fixed and Released in Version: | 13.02.00.19 (13.02.01.25) | ||
Environment: | x64 | ||
Area: | File; Database | ||
Issue #: | 1066548 |
When assigning a CBB Gusset connection to an existing joint with a 90 degree column orientation, an error message saying "Object reference not set to an instance of an object" occurs. After closing the error box, none of the other CBB joint thumbnails are displayed.
Also affects Ram Connection for Ram Elements or Ram Connection for Ram Structural System.
Programming error.
Fixed in version 13.02.00.19 (available from Technical Support through a Service Request), and in the official release 13.02.01.25 or thereafter.
File corruption after conversion - Access Violation
Software Download Instructions
