SOILVISION CONNECT Edition V10 Update 1 Release Notes
Release: January 2020
SOILVISION CONNECT Edition V10 Update 1 (10.01.00.329) contains the following improvements and updates compared to SOILVISION CONNECT Edition V10 (10.00.00.13):
New and improved features
Learn more about other recent improvements to the SOILVISION products on the SOILVISION Recent Improvements wiki page of Bentley Communities. SOILVISION products include SVDESIGNER, SVSOILS, SVSLOPE, SVFLUX, SVSOLID, and SVENVIRO.
OpenGround Cloud Borehole Import
Import into SVDESIGNER and keep updated borehole data from OpenGround Cloud (formerly Keynetix.cloud).
PLAXIS 2D Interoperability - Technology Preview
Transfer SVSLOPE, SVSOLID, SVFLUX, or SVENVIRO model geometry into PLAXIS 2D.
2D Dynamic Seismic Input for Slope Stability - Technology Preview
Solve dynamic seismic finite-element models and use the results in an SVSLOPE 2D limit-equilibrium analysis. This functionality adds to other standard seismic methods in SVSLOPE like Pseudo-Static Coefficients, Spectral Pseudo-Static, and Newmark.
Fix Region Geometry Tool
This action can fix most region geometry issues that cause problems with the model, such as gaps between regions, overhanging regions on the ground edges, extremely thin regions, and more.
Adjust Overlap Options
New options added for the Adjust Overlap operation in SVDESIGNER.
Export FOS as an Image and Mesh
New options to export FOS results as an image and mesh.
Copy MPA Lines
Multi-Plane Analysis (MPA) lines can be copied from one SVSLOPE model to another.
DXF Export Mesh Support
DXF Export now supports meshes.
Custom Slice Shift
SVDESIGNER option added to shift the X axis coordinate system of a custom slice.
Piezometer time-value visualization
Piezometer time-value visualization added to SVDESIGNER.
Borehole Water Depth
Added water depth support for boreholes in SVDESIGNER.
Volume Legend Updates
Volume legend upgraded to display material names, colors, and textures in SVDESIGNER.
Apply Merge Distance Performance
Apply Merge Distance performance with very large data sets improved.
General Meshing Improvements
Various general meshing improvements implemented.
Large Mesh Improvements
Performance improvements when using large meshes.
Axis Position Offsets
Axis position offsets can now be defined in model coordinates.
Improved Trial Slip Surface Reporting
Improved trial slip surface reporting in SVSLOPE.
Hot Key Documentation
Help content added for hot keys available.
Fixed issues
