| Product(s): | InRoads |
| Version(s): | 08.11.07.615 |
| Area: | Geometry |
| Original Author: | Sanders Thomas, Bentley Technical Support Group |
Problem:
I am trying to load InRoads ALG file in ProjectWise and receiving a message "Unable to lock file". The file does not open. I can export the file and open locally, but it does not work when I import the file back to ProjectWise.
Go to Tools < Application Add-ins. Check to make sure you have "Variable Manager" toggled on.
Go to Tools > Variable Manager> Command Behavior, and ensure that "Geometry - Alternate Workflow with ProjectWise" is selected. This command will automatically check-out and check-in the ALG and should resolve this issue.
