DNV Piping Code Calculation Issues in AutoPIPE
Note: Please see the following AutoPIPE help section:
Help > Contents> Contents Tab> Reference Information> Code Compliance Calculations> select a piping code to see the calculations performed by AutoPIPE.
Comments, Questions, and Answers about DNV piping code calculations in AutoPIPE
Item #1: Von Mises stress calculations results are different than automatically calculated ASD
Item #2: DNV 2012 references a new definition of bending, but AutoPIPE help is different
Item #3:  ASD results are lower than the hoop stress results
Item #4: Difference between general stress results and user Von mises results
Item #5: Results for DNV code combinations Collapse and Prop Buck are 0.00 or very small
Item #6:  DNV 2012 Results Options dialog
Item #7:  DNV 2000 availability
Item #8:  Explain Load Controlled Buckling check "stress value" and "allowable value"
Item #9:  Which category should be chosen to accommodate DNV-OS-F101 standard. section 5 "DESIGN – LIMIT STATE CRITERIA", D 600 Local buckling combined loading criteria
Item #10: Max Utilization Ratio for combined load case was less than Max Utilization Ratio for a single load case
Item #11: Calculate the Forces and Moments to evaluate the "DNV local buckling category"
Item #12: Pressure consideration for DNV limits v/s stress design "ASDC"
Item #13: Are manually calculated SIF / SCF values used in DNV 2012 ASD calculations?
Item #14: Use AutoPIPE for Ultra deep water analysis
Item #15: ASD 2017 code calculation
Piping Code Calculations
