| Version | PLAXIS 2D PLAXIS 3D |
| Date created | 23 February 2012 |
| Date modified | 23 February 2012 |
This video demonstrates the use of the command line.
The command line provides access to specialized commands and supports the workflow in complex projects.
For the latest available commands and their signatures (structure and parameters), please refer t0 the Command and Object reference, available via the Help menu. See also Command line reference.
