"Autopipe.exe" Messages displayed in AutoPIPE
The following messages appear in AutoPIPE:
Item #1: "The application failed to initialize properly (0xc0150002)"
Item #2: autopipe.exe - No Disk
There is no disk in the drive. Please insert a disk into drive\Device\Harddisk2\DR2.
Item #3: "The application was unable to start correctly (0xc0000005)"
Item #4: The code execution cannot proceed because IEGlicLib.dll was not found
Item #5: This application has failed to start because IEGLicLib.dll was not found
Warnings, Errors, Crashed, Confirm Messages
