Product(s): | OpenRoads Designer, OpenRail Designer |
Version(s): | 10.11.00+ |
Area: | Model Detailing |
Original Author: | Joe Waxmonsky, Senior Product Manager - Bentley Systems |
When running the Create Cut Fill Volumes tool multiple times, it is often desired to remove the 3D meshes that were generated by the tool previously. Beginning in Version 10.11, the user will be prompted to "Delete Previous Results". This following video demonstrates this new option.
