W726-9: A Guide or Line Stop should not be inserted at following kink point(s)...message appears w
Product(s):AutoPIPE
Version(s):ALL;
Area: Warning
Date Logged
& Current Version
July 2021
12.06.00.48
Problem:
The following is displayed in model consistency check report:
Instead, insert a new run point near the kink to add the support.
Why and how to avoid the issue.
As the warning message indicates, support(s) was found at a kink in the pipe run or a kink in the pipe was found at the exact location as a support. This can be checked by reviewing the model consistency report where both warning messages would have occurred at the same node point: (Example E09)
W726-8:   Kink in straight run at following point(s):
E09         1.4  deg
E09
Typically there should be a straight run of pipe at supports locations.
Workaround:
1. Move the support to a straight run of pipe
2. Straighten the piping to avoid kinks.
"Warnings" Messages
