01. Bentley AutoPIPE Application has stopped working - "A problem caused the....
The following is displayed:
"A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available."
Item #1: Crashing when the user clicks "save."
Item #2: Program crashes on exporting buried pipe options to NTL
Item #3: Program crashed when pressing the "Generate Default description" button on the Load> Load Case Description dialog screen.
Item #4: Program crashed when pressing the "Renumbering" button on the toolbars in AutoPIPE.
Item #5: Program crashed when importing NTL file into AutoPIPE
Item #6: Program crashed when Importing a PXF file into AutoPIPE.
Application Crashed or Freezes - AutoPIPE
