ProStructures CONNECT for AutoCAD (2021-2024) Update 2 (10.02.00.04)
ProStructures CONNECT Edition for AutoCAD Update 2 (10.02.00.04) is now available on Software Downloads.
ProStructures CONNECT Edition for AutoCAD Update 2 supports AutoCAD 2021, AutoCAD 2022, AutoCAD 2023 and AutoCAD 2024 (64 bit)
This product version utilizes CONNECT Licensing, which is not supported by SELECT Activation Key(s). CONNECT Licensing features new behavior to enhance your organization’s user administration and security with mandatory user sign-in via CONNECTION Client to access the application. If you are already signed in to the CONNECTION Client, you have met this prerequisite. If you have not, please refer to the Administrator's Resource Center and/or contact your administrator for assistance in the registration and sign-in process.
Readme
