| Version(s): | through 10.01.00.23 | ||
| Area: | Administration Features | ||
| Subarea: | Setup |
How do I rename a catalog?
The name of a catalog as it appears on various dialogs in the software is the name of the catalog's folder. Therefore renaming a catalog entails renaming the folder.
Note the path of the catalog on [[Catalog Paths]].
All users configured to use the catalog that will be renamed should close the software.
Browse to the catalog's folder noted in step 1 using Windows Explorer.
Rename the catalog's folder to the new catalog name.
Users can then [[Add Catalog Path|add the catalog back to their configuration]].
[[Add Catalog Path]]
| Original Author: | Matt_P |
