Product(s): | Promis.e CONNECT Edition | ||
Version(s): | 10.00.XX.XX to 10.07.XX.XX | ||
Environment: | NA | ||
Area: | Component Management | ||
Subarea: | Parts Database |
Users sometimes may need to copy Parts Database records from an MDB file to the existing Parts Database which is being used with Promis.e. This is usually needed if you are trying to use Part Records from a new Catalogs.
Note: The below steps require MS Office Access, hence check if you have it installed on your machine before proceeding.
1. Create a copy of the already existing parts database that is currently being used by Promis.e and into which the new Part Number records need to be added. And open the Table Associated with part Number records in both the MDB files.
2. Create a copy of the already existing parts database that is currently being used by Promis.e and into which the new Part Number records need to be added. And open the Table Associated with part Number records in both the MDB files.
3. Then make sure that all the Columns are the same for both the MDB files and are in the same sequence. This needs to be checked correctly for each column in both the MDB files so that the data maintained with the same information. If there is any difference the column needs to be added accordingly in both the MDB files.
4. Once the Columns are maintained, the next is to copy the data fields from the Source MDB file to Target MDB by selecting all the details as required. Make sure that the Column header is not selected.
5. After the part details have been copied open the Target MDB file and past the parts data below the existing parts data.
6. Now copy the MDB file where the Parts Data is copied and replace it with the Parts Database MDB file currently being used by Promis.e as referred to in step 1.
Note: Before copying MDB file, if the existing file is currently being used by Promis.e then close Promis.e before making the changes.
Alternatively, the user can also use SQL Management Studio (SSMS) to copy the data from Source MDB to Target MDB. The user can refer to the below link for the details on the same.
docs.microsoft.com/.../connect-to-a-mysql-data-source-sql-server-import-and-export-wizard
docs.microsoft.com/.../choose-a-data-source-sql-server-import-and-export-wizard
docs.microsoft.com/.../choose-a-destination-sql-server-import-and-export-wizard
communities.bentley.com/.../how-to-create-parts-database-path-using-mdb-file-in-promise-connect
Original Author: | Satish Saptasagar |
