| Product(s): | ProSteel | ||
| Area: | Shapes | ||
| Subarea: | General | ||
In this wiki, we are going to learn how to load or remove the shape catalogs in the Shape tool.
1. Open the Shapes tool located under Steel workflow > Home > Steel Placement.
2. Left-click on the Shape Catalog button to open it.
3. Now, check the box for your required shape catalog and uncheck all remaining catalogs.
4. Left-click on the left double arrow button which will delete all the shape classes from the Current Shape Classes section.
5. Now, left-click on the double right arrow button to copy or load all the shape classes to the Current Shape Classes section. Once done then click on the
OK button.
6. In the Shapes tool, under the Shape Class section, you can see all the copied shape classes get loaded.
In this way, we can load or remove the shape catalogs in the Shapes tool.
