Product(s): | OpenSite, OpenRoads, OpenRail Designer Connect Edition |
Version(s): | 2023+ |
Area: | Drainage & Utilities |
In the past when you compute the hydraulics, the software will compute all networks in the design model. You could isolate networks by using the Active Topology Alternative to group nodes and links under a named topology. Beginning in the 2023 version of the Open Civil products you can now click on an outlet node of a network and hover to get a heads-up icon that allows you to set the subnetwork inactive. This will toggle the "Is Active" Utility property for all components of that subnetwork to "False" so that when you compute a scenario they will not be considered.
Click the video below to play it. To view in fullscreen mode, first click the YouTube link at the bottom of the video to launch the video on the YouTube site. Then, click the fullscreen button (rightmost button at bottom of video).
