| Version(s): | 10.04.00.48+ |
| Area: | Drawing Production |
| Original Author: | Holly Herring, Bentley Technical Support Group |
How do you create skewed cross section Named Boundaries?
When you use the Place Named Boundary tool, use the Civil Cross Section 2 Points to place the skewed cross section. Be sure to select the Group you want it to be added to.
