| Product(s): | GEOPAK, MX |
| Version(s): | 08.11.09.932 |
| Area: | Startup |
Question:
When launching the Power GEOPAK, GEOPAK or MX SS10 08.11.09.932 versions, a command window appears showing the message "MDL Loader: Could not load application AppCensus"
Answer:
This is a known issue that does not affect behavior or performance of the program. Since support for the V8i products has been discontinued, there are no plans for future releases to remove the code causing this error.
