Is there a way to propagate changes to multiple dimension styles at one time?
 Product(s):MICROSTATION
 Version(s):V8i and CONNECT Edition
 Environment: N\A
 Area: Dimensions
 Subarea: Dim Styles
Select the dimension styles that you want to save by either holding the CTRL button or Shift buttons while selecting with a data point to do a multiple selection set. Once this is done, select the Save Style icon and all of the dimension styles selected will be saved. This will also work for changing attributes in multiple dimension styles as well.
