| Area: | Manipulation | ||
| Subarea: | N\A |
When I select an element and want to move it by dragging, the drag operation does not work, I am not able to move the element (without selecting the move tool).
1. Go to Workspace > Preferences
2. Select Category Input
3. Check if there is option Disable Drag Operations selected > remove the tick mark
1. Go to File > Settings > User > Preferences
| Original Author: | Anu Kuusiaho |
