| Version(s): | All | ||
| Subarea: | Properties | ||
There is a property named Ct that I see within the W shape table of the AISC steel section database. What does this stand for?
The Ct parameter is applicable only for T shapes being cut from W shapes. The parameter denotes the distance of the cg of the T section ( cut from the W shape ) from the flange as shown in the diagram below.
