| Product(s): | ProSteel |
| Version(s): | All |
| Area: | Steel Connections |
| Subarea: | N/A |
| Original Author | Steffen Knoll, Bentley Technical Support Group |
| Updated By: | Vyanktesh Nama, Bentley Technical Support Group |
Groups have been created manually. After changing a connection the group doesn't exist anymore
Updating a connection results in updating all settings of a connection.
Use the connection group settings instead of manual group creation to avoid this problem.
Some connections have a tab for groups, such as the endplate connection:
Others have the group options on the main tab Layout like the base plate connection:
