| Version(s): | 08.05.01.25 | ||
| Area: | Custom Linestyles | ||
| Subarea: | N\A | ||
How to rename a linestyle component description.
Go to Element > Line Styles > Edit.
In the linestyle editor go to File > Open and open the linestyle resource file to be modified.
Once theresource file is opened. On the component side highlight the component
at the top and then in the middle highlight the description and change as required.
