Issue when loading the ISM Engine with Structural Synchronizer
Product(s):ProStructures, Structural Synchronizer, ISM Engine
Version(s):CONNECT Edition
Environment:N/A
Area:Import/Export
Subarea:ISM Repository
Original Author:Alistair Lobo, Bentley Product Advantage Group
Creating, Importing or Exporting ISM Repositories to and from ProStructures via the Structural Synchronizer (11.04.01.04) fails and throws up an Error Message as below -
1. Uninstall the older Structural Synchronizer on your machine.
2. Delete the older Structural Synchronizer/iTwin Analytical Synchronizer CONNECT Edition folders from the below locations (if exists).
- C:\Program Files\Bentley\Engineering
- C:\Program Files (x86)\Bentley\Engineering
3. After this, install the compatible version of Structural Synchronizer w.r.t the ProStructures version.
Product NameCompatible Structural Synchronizer/iTwin Analytical Synchronizer versions with download link
ProStructures CONNECT Edition Update 7.2 (10.07.02.33)11.01.02.09, 12.00.00.08, 12.01.01.01, 12.02.00.139, 12.02.01.10
ProStructures CONNECT Edition Update 7.1 (10.07.01.59)
ProStructures CONNECT Edition Update 7 (10.07.00.79)11.01.02.09, 12.00.00.08, 12.01.01.01, 12.02.00.139
ProStructures CONNECT Edition Update 6.1 (10.06.01.59)10.03.01.06, 11.00.00.15, 11.00.03.04, 11.01.02.09, 12.00.00.08, 12.01.00.285
ProStructures CONNECT Edition Update 6 (10.06.00.60)10.03.01.06, 11.00.00.15, 11.00.03.04, 11.01.02.09, 12.00.00.08, 12.01.00.285
ProStructures CONNECT Edition Update 5.2 (10.05.02.51)10.03.01.06, 11.00.00.15, 11.00.03.04, 11.01.02.09, 12.00.00.08, 12.00.01.19
ProStructures CONNECT Edition Update 5.1 (10.05.01.11)11.00.03.04, 11.01.02.09
ProStructures CONNECT Edition Update 5 (10.05.00.54)11.00.03.04, 11.01.02.09
ProStructures CONNECT Edition Update 4 (10.04.00.47)11.00.00.15
4. Launch the Structural Synchronizer/iTwin Analytical Synchronizer CONNECT Edition application before creating ISM and then create ISM.
This should resolve your issue and you will be able to create and import/export the ISM repositories as normal.
