How do I re-align a bridge to a new alignment?
To set or change the alignment for the active bridge unit, use the following procedure.
You must have at least one alignment in your bridge project.
This feature can be used to realign an existing bridge unit to a new alignment. All calculated geometry will be updated to the selected alignment.
- Either:
On the Home ribbon tab, select the Alignment tool in the Bridge Setup group
or
key in BMGEOM
ALIGNMENT
ACTIVE
- Data point on an alignment in the view window. The current active bridge unit will be set on this alignment.
