Introduction to Data Loggers with KeyLAB
Data Converting
The KeyLAB data converter is designed to allow for the conversion of datalogger data into a format that KeyLAB can recognize. We are using the data converter feedback tool to perform this process. The tool will convert from whatever format we set up to in XML format putting the data onto the worksheets and it’s important.
Using the Data Converter and Importing Into KeyLAB
The Video guide below will show how to use the tools once you have a script you can convert the data with
https://vimeo.com/546433115
Creating Script Files for Converting Data
The next pages of this guide will go step-by-step on how to create these data conversion scripts. It will highlight the key steps and it will also show tips and tricks on how to make sure the process can be smooth and simple.
How to Start
