Original Author: Bentley Technical Support Group -VM
QUESTION: For the case of pier columns supported by individual drilled shafts is the shaft treated as part of the column and therefore the P-delta effects are applied in the design of the shaft as well ?
ANSWER:
Yes the shaft is treated as part of the column and the p delta effects are applied in the design of shaft as well.
