Welcome to the OpenComms Wiki Page!
OpenComms Designer and OpenComms PowerView are available NOW!
OpenComms Designer blends traditional engineering workflows for planning, engineering, construction, and maintenance under one GIS system that includes the accuracy of the CAD deliverables you’ve grown to expect from Bentley. OpenComms Designer is the successor to Bentley’s industry-leading communication products, replacing the capabilities of the following applications into a single offering: Bentley Fiber, Bentley Coax, Bentley Inside Plant, and Expert Designer for Communications.
OpenComms PowerView replaces CPV with a new and faster 64bit environment for opening large files in the field and performing faster reviews and traces on Comms devices.
